Philco 97 - RF problem... HELP!
Got the sheets for 98 and yes mine is 98 yours is 97. That corner block is same as in yours just moved into the corner and an additional cap and resistor added in its original location. So there was no other block in yours. This does not help you any with your RF problem.
My suggestion for what it is worth is to go through your schematic and check all the circuit for any error. Then look at components including if there are mica's in the RF can. Please dont do a Hakka on me over these Mica's steve its just my way of trying to crack the problem. Other suggestions are The pub. The top of a mountain and scream or finally bring the chassis to a field with a pound of those explosives .................
Philco 97 - RF problem... HELP! - by kiwi_steve - 05-01-2016, 09:38 PM
RE: Philco 97 - by KCMike - 05-01-2016, 09:53 PM
RE: Philco 97 - by kiwi_steve - 05-01-2016, 11:59 PM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 03:02 AM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 03:18 AM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 11:50 PM
RE: Philco 97 - by kiwi_steve - 05-03-2016, 02:41 AM
RE: Philco 97 - by kiwi_steve - 05-07-2016, 08:27 PM
RE: Philco 97 - by Mondial - 05-08-2016, 10:25 AM
RE: Philco 97 - by HOTWIRE - 05-08-2016, 11:44 AM
RE: Philco 97 - by kiwi_steve - 05-08-2016, 12:27 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 09:55 AM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 03:55 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 12:44 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 05:01 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 05:28 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 05:49 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 05:31 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 07:51 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 08:31 PM
RE: Philco 97 - by kiwi_steve - 05-10-2016, 01:32 AM
RE: Philco 97 - by HOTWIRE - 05-10-2016, 05:28 AM
RE: Philco 97 - by kiwi_steve - 05-10-2016, 06:33 AM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 05-12-2016, 05:20 AM
RE: Philco 97 - RF problem... HELP! - by morzh - 05-12-2016, 07:34 AM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 05-12-2016, 08:58 AM
RE: Philco 97 - RF problem... HELP! - by Mondial - 05-15-2016, 03:18 PM
RE: Philco 97 - RF problem... HELP! - by Mondial - 05-15-2016, 07:21 PM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 06-20-2016, 09:38 PM
