Philco 97 - RF problem... HELP!
No hakkas from me... problem is, there are just no silver mica's in this circuit that can be changed. The only one is the 110pF cap to ground from the primary side... there's nothing on the secondary - which is the tuned side. Just the trimmers, but those work fine.
I will go over the wiring again tomorrow, its got to be something... probably something I did.
There are no personal problems that can't be overcome with the liberal application of high explosives
Philco 97 - RF problem... HELP! - by kiwi_steve - 05-01-2016, 09:38 PM
RE: Philco 97 - by KCMike - 05-01-2016, 09:53 PM
RE: Philco 97 - by kiwi_steve - 05-01-2016, 11:59 PM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 03:02 AM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 03:18 AM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 11:50 PM
RE: Philco 97 - by kiwi_steve - 05-03-2016, 02:41 AM
RE: Philco 97 - by kiwi_steve - 05-07-2016, 08:27 PM
RE: Philco 97 - by Mondial - 05-08-2016, 10:25 AM
RE: Philco 97 - by HOTWIRE - 05-08-2016, 11:44 AM
RE: Philco 97 - by kiwi_steve - 05-08-2016, 12:27 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 09:55 AM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 03:55 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 12:44 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 05:01 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 05:28 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 05:49 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 05:31 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 07:51 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 08:31 PM
RE: Philco 97 - by kiwi_steve - 05-10-2016, 01:32 AM
RE: Philco 97 - by HOTWIRE - 05-10-2016, 05:28 AM
RE: Philco 97 - by kiwi_steve - 05-10-2016, 06:33 AM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 05-12-2016, 05:20 AM
RE: Philco 97 - RF problem... HELP! - by morzh - 05-12-2016, 07:34 AM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 05-12-2016, 08:58 AM
RE: Philco 97 - RF problem... HELP! - by Mondial - 05-15-2016, 03:18 PM
RE: Philco 97 - RF problem... HELP! - by Mondial - 05-15-2016, 07:21 PM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 06-20-2016, 09:38 PM
There are currently 5504 online users. [Complete List]
» 2 Member(s) | 5502 Guest(s)
