Model 38-3 and another wonderful RF unit
From the looks of it, the 1936 Model 680 will give you a "run for your money" as well. That I.F. expander unit and the bandswitch...yikes!
Icon_smile
[No subject] - by 49Stude63 - 01-05-2006, 09:22 PM
[No subject] - by Ron Ramirez - 01-05-2006, 09:55 PM
[No subject] - by 49Stude63 - 01-05-2006, 10:34 PM
[No subject] - by Chuck Schwark - 01-05-2006, 10:39 PM
[No subject] - by Fred R - 01-06-2006, 10:52 PM
[No subject] - by Ron Ramirez - 01-06-2006, 11:00 PM
[No subject] - by 49Stude63 - 01-06-2006, 11:03 PM
[No subject] - by Fred R - 01-06-2006, 11:31 PM
[No subject] - by Poston Drake - 01-08-2006, 12:12 AM
There are currently 8922 online users. [Complete List]
» 3 Member(s) | 8919 Guest(s)
