Philco 97 - RF problem... HELP!
AND do you have the radio to ground. Separate from house ground. IE uncouple the house ground from the plug (no ground to house.) I have a Rebar thumped down into DAMP earth outside the house with a cable running to my radio room which I hook up to Radio. For Safety I have a Knife switch isolating the ground AND separately the External Arial as protection in the event of lightning. I shut down everything from a master switch and drop the knife switch as a habit.
So
1. Good external Arial check.
2. External ground check.
3. Check the nica on the inside to of the can.
3 follow Terry,s suggestion above to de-tune or re-tune the rf.
Wow. Great Hakka.
Will.
Philco 97 - RF problem... HELP! - by kiwi_steve - 05-01-2016, 09:38 PM
RE: Philco 97 - by KCMike - 05-01-2016, 09:53 PM
RE: Philco 97 - by kiwi_steve - 05-01-2016, 11:59 PM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 03:02 AM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 03:18 AM
RE: Philco 97 - by kiwi_steve - 05-02-2016, 11:50 PM
RE: Philco 97 - by kiwi_steve - 05-03-2016, 02:41 AM
RE: Philco 97 - by kiwi_steve - 05-07-2016, 08:27 PM
RE: Philco 97 - by Mondial - 05-08-2016, 10:25 AM
RE: Philco 97 - by HOTWIRE - 05-08-2016, 11:44 AM
RE: Philco 97 - by kiwi_steve - 05-08-2016, 12:27 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 09:55 AM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 03:55 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 12:44 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 05:01 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 05:28 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 05:49 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 05:31 PM
RE: Philco 97 - by HOTWIRE - 05-09-2016, 07:51 PM
RE: Philco 97 - by kiwi_steve - 05-09-2016, 08:31 PM
RE: Philco 97 - by kiwi_steve - 05-10-2016, 01:32 AM
RE: Philco 97 - by HOTWIRE - 05-10-2016, 05:28 AM
RE: Philco 97 - by kiwi_steve - 05-10-2016, 06:33 AM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 05-12-2016, 05:20 AM
RE: Philco 97 - RF problem... HELP! - by morzh - 05-12-2016, 07:34 AM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 05-12-2016, 08:58 AM
RE: Philco 97 - RF problem... HELP! - by Mondial - 05-15-2016, 03:18 PM
RE: Philco 97 - RF problem... HELP! - by Mondial - 05-15-2016, 07:21 PM
RE: Philco 97 - RF problem... HELP! - by HOTWIRE - 06-20-2016, 09:38 PM
Users browsing this thread: 13 Guest(s)
There are currently 5418 online users. [Complete List]
» 3 Member(s) | 5415 Guest(s)
