Philco 89 how well do they perform
Personally, I've always been quite fond of the 89 and 19 series Philco sets.
Sure, they have a bad reputation due to the finicky oscillator coil that is always bad. But if that coil is properly taken care of (removed, baked in an oven at 200 degrees for 15-20 minutes to drive out moisture, then properly rewound and coated with lacquer), and the set properly restored, it will reward you with outstanding performance.
Even the models with the type 36 detector-oscillator tube are capable of working very well. The later ones with a 77 tube in this position are somewhat more reliable.
I developed a mod to convert the detector-oscillator tube to a 6A7. But really, a properly restored stock set will work just about as well.
Details here:
http://philcoradio.com/phorum/showthread.php?tid=1310
Philco 89 how well do they perform - by radiorich - 06-22-2009, 01:27 AM
Re: Philco 89 how well do they perform - by exray - 06-22-2009, 07:26 AM
Re: Philco 89 how well do they perform - by Ron Ramirez - 06-22-2009, 11:00 PM
Re: Philco 89 how well do they perform - by exray - 06-24-2009, 02:55 AM
Re: Philco 89 how well do they perform - by exray - 06-24-2009, 09:18 AM
Ron Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text t...morzh — 02:00 PM
Eico 232 VTVM Schematic
There are currently 6567 online users. [Complete List]
» 2 Member(s) | 6565 Guest(s)
