Philco 680
I want one Icon_smile
Can anyone shed some light on the performance of the passive radiators? How much of a difference do they actually make - or are they a marketing gimmick? I can't see how they can do all that much without a sealed cabinet (although I guess if the radio was up against a wall then higher volumes are going to have some effect using the wall as a pseudo-back-panel.
There are no personal problems that can't be overcome with the liberal application of high explosives
Philco 680 - by vaguy22 - 05-08-2016, 11:35 AM
RE: Philco 680 - by KCMike - 05-08-2016, 12:09 PM
RE: Philco 680 - by palegreenthumb - 05-08-2016, 12:34 PM
RE: Philco 680 - by Phlogiston - 05-08-2016, 01:21 PM
RE: Philco 680 - by Radioroslyn - 05-08-2016, 06:14 PM
RE: Philco 680 - by morzh - 05-08-2016, 04:37 PM
RE: Philco 680 - by Radioroslyn - 05-08-2016, 06:11 PM
RE: Philco 680 - by Radioroslyn - 05-08-2016, 05:58 PM
RE: Philco 680 - by vaguy22 - 05-08-2016, 07:53 PM
RE: Philco 680 - by titan1a - 05-08-2016, 08:56 PM
RE: Philco 680 - by vaguy22 - 05-10-2016, 12:12 PM
RE: Philco 680 - by KCMike - 05-10-2016, 02:08 PM
RE: Philco 680 - by Arran - 05-11-2016, 03:59 AM
RE: Philco 680 - by vaguy22 - 05-11-2016, 09:34 PM
RE: Philco 680 - by Arran - 05-12-2016, 03:22 AM
RE: Philco 680 - by SteveG - 05-11-2016, 11:40 PM
RE: Philco 680 - by kiwi_steve - 05-12-2016, 04:41 AM
RE: Philco 680 - by vaguy22 - 05-12-2016, 10:12 AM
RE: Philco 680 - by morzh - 05-12-2016, 10:21 AM
RE: Philco 680 - by vaguy22 - 05-13-2016, 10:31 AM
RE: Philco 680 - by vaguy22 - 05-13-2016, 10:38 AM
RE: Philco 680 - by vaguy22 - 05-13-2016, 10:41 AM
RE: Philco 680 - by kiwi_steve - 05-13-2016, 06:02 PM
RE: Philco 680 - by vaguy22 - 05-13-2016, 09:19 PM
RE: Philco 680 - by Mondial - 05-13-2016, 09:24 PM
RE: Philco 680 - by morzh - 05-14-2016, 09:17 PM
RE: Philco 680 - by Arran - 05-15-2016, 03:44 AM
RE: Philco 680 - by kiwi_steve - 05-15-2016, 06:13 AM
RE: Philco 680 - by morzh - 05-15-2016, 10:42 AM
RE: Philco 680 - by vaguy22 - 05-15-2016, 11:27 AM
RE: Philco 680 - by Radioroslyn - 05-15-2016, 03:00 PM
RE: Philco 680 - by morzh - 05-15-2016, 04:03 PM
RE: Philco 680 - by vaguy22 - 05-15-2016, 07:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
