Philco 40-190 Humming Along?
Problem solved! There were 2 miswires in the B+ supply. The connections to the field coil were "swapped" resulting in nearly the entire secondary load being connected to the input side of the FC, instead of the output side of the FC! Partly due to 2 identical capacitors used in the secondary PS filter (C61 and C58).
Sigh, it's always where you least expect to find the problem...
Mike
Philco 40-190 Humming Along? - by Mike Schettler - 04-06-2016, 07:41 PM
RE: Philco 40-190 Humming Along? - by klondike98 - 04-06-2016, 08:17 PM
RE: Philco 40-190 Humming Along? - by Radioroslyn - 04-06-2016, 08:34 PM
RE: Philco 40-190 Humming Along? - by fifties - 04-06-2016, 10:59 PM
RE: Philco 40-190 Humming Along? - by Radioroslyn - 04-07-2016, 08:43 PM
RE: Philco 40-190 Humming Along? - by fifties - 04-09-2016, 07:37 PM
RE: Philco 40-190 Humming Along? - by Mike Schettler - 05-13-2016, 08:17 PM
RE: Philco 40-190 Humming Along? - by KCMike - 05-13-2016, 09:19 PM
RE: Philco 40-190 Humming Along? - by morzh - 05-14-2016, 07:33 PM
RE: Philco 40-190 Humming Along? - by klondike98 - 05-14-2016, 06:56 PM
There are currently 5527 online users. [Complete List]
» 2 Member(s) | 5525 Guest(s)
