1930 model 96
Greg, I bet that that 96 is unrestored and playing on all its original parts. As far as I recall, the 96 has no electrolytics, but uses a paper capacitor block for filters.
Actually I would not be surprised if it has been playing as is every day in the store . I have a
Philco 77 which is unrestored and totally original, right down to the Philco globe tubes. I don't use it much, but it still plays great when I power it up
1930 model 96 - by NostalgiaRadioTime - 05-14-2016, 02:47 PM
RE: 1930 model 96 - by NostalgiaRadioTime - 05-14-2016, 02:49 PM
RE: 1930 model 96 - by KCMike - 05-14-2016, 04:13 PM
RE: 1930 model 96 - by Mondial - 05-14-2016, 08:06 PM
RE: 1930 model 96 - by morzh - 05-14-2016, 09:09 PM
RE: 1930 model 96 - by NostalgiaRadioTime - 05-14-2016, 11:56 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
