Philco 39-6 dial cover and grill cloth.
Probably best bet to call. I contacted him by phone quite awhile back. Nice guy and helpful.
RE: Philco 39-6 dial cover - by OldRestorer - 05-15-2016, 07:53 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 08:26 PM
RE: Philco 39-6 dial cover - by KCMike - 05-15-2016, 09:10 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 09:16 PM
RE: Philco 39-6 dial cover - by KCMike - 05-15-2016, 09:27 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 09:37 PM
RE: Philco 39-6 dial cover - by Arran - 05-18-2016, 11:24 PM
RE: Philco 39-6 dial cover - by morzh - 05-19-2016, 08:37 AM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:05 PM
RE: Philco 39-6 dial cover - by KCMike - 05-20-2016, 07:22 PM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:24 PM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:52 PM
There are currently 10536 online users. [Complete List]
» 2 Member(s) | 10534 Guest(s)
