Detrola Series 175 Push Buttons
Hi John,
I don't have any pushbuttons to send, but I was going to send photos and measurements of what they look like.
I'll email you photos this afternoon.
Just the plastic part is missing? Or the whole plastic and brass contact rod?
I think that if you had a small lathe or even some plastic rod material, (swirled brown plastic) you'd be able to make your own. I'm going to make the photos now.
Gary.
Detrola Series 175 Push Buttons - by Guest - 12-01-2008, 09:54 AM
Re: Detrola Series 175 Push Buttons - by Guest - 06-21-2009, 08:14 PM
Re: Detrola Series 175 Push Buttons - by gary rabbitt - 06-24-2009, 12:00 PM
Eico 232 VTVM Schematic
There are currently 6533 online users. [Complete List]
» 2 Member(s) | 6531 Guest(s)
