I neeeeed opinions..
Well, I don't like the cabinet or the flip top. I don't like consoles with record players especially in the belly. So I would not take it if you gave it to me - really. But if you like it then that's OK.
I neeeeed opinions.. - by OldRestorer - 05-17-2016, 06:13 PM
RE: I neeeeed opinions.. - by sam - 05-17-2016, 06:55 PM
RE: I neeeeed opinions.. - by Radioroslyn - 05-17-2016, 07:03 PM
RE: I neeeeed opinions.. - by Joe Rossi - 05-17-2016, 07:12 PM
RE: I neeeeed opinions.. - by OldRestorer - 05-17-2016, 07:27 PM
RE: I neeeeed opinions.. - by Ron Ramirez - 05-17-2016, 08:21 PM
RE: I neeeeed opinions.. - by morzh - 05-17-2016, 07:46 PM
RE: I neeeeed opinions.. - by Phlogiston - 05-18-2016, 01:51 AM
RE: I neeeeed opinions.. - by Ron Ramirez - 05-18-2016, 09:50 AM
RE: I neeeeed opinions.. - by OldRestorer - 05-18-2016, 10:57 AM
RE: I neeeeed opinions.. - by Phlogiston - 05-18-2016, 05:38 PM
RE: I neeeeed opinions.. - by OldRestorer - 05-18-2016, 07:01 PM
RE: I neeeeed opinions.. - by morzh - 05-18-2016, 07:37 PM
RE: I neeeeed opinions.. - by KCMike - 05-18-2016, 07:37 PM
RE: I neeeeed opinions.. - by Arran - 05-19-2016, 12:31 AM
RE: I neeeeed opinions.. - by sam - 05-19-2016, 02:15 PM
RE: I neeeeed opinions.. - by morzh - 05-19-2016, 03:06 PM
RE: I neeeeed opinions.. - by OldRestorer - 05-19-2016, 04:03 PM
RE: I neeeeed opinions.. - by sam - 05-19-2016, 07:48 PM
RE: I neeeeed opinions.. - by Ron Ramirez - 05-19-2016, 08:19 PM
RE: I neeeeed opinions.. - by morzh - 05-19-2016, 08:10 PM
RE: I neeeeed opinions.. - by OldRestorer - 05-20-2016, 08:08 AM
RE: I neeeeed opinions.. - by morzh - 05-20-2016, 09:14 AM
RE: I neeeeed opinions.. - by Phlogiston - 05-20-2016, 11:01 AM
RE: I neeeeed opinions.. - by morzh - 05-20-2016, 11:17 AM
RE: I neeeeed opinions.. - by OldRestorer - 05-21-2016, 05:42 PM
RE: I neeeeed opinions.. - by morzh - 05-21-2016, 06:58 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
