37-61 Issues
Here is a link to the schematic for anyone else following this thread:
http://www.nostalgiaair.org/pagesbymodel...013208.pdf
I'll let one of the resident experts chime in, but until then you might want to check some tube voltages.  You can also check the output transformer ( #38 ) for 400 ohms.
I doubt that one resistor is the problem, but if one of them is out-of-spec that much then there are probably more that need to be changed.
37-61 Issues - by Tgace459 - 05-18-2016, 07:53 AM
RE: 37-61 Issues - by KCMike - 05-18-2016, 08:47 AM
RE: 37-61 Issues - by Steve Davis - 05-18-2016, 08:47 AM
RE: 37-61 Issues - by Eliot Ness - 05-18-2016, 08:59 AM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 09:14 AM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 09:18 AM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 10:43 AM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 12:09 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 01:22 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 01:25 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 01:34 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 01:45 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 01:47 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 01:55 PM
RE: 37-61 Issues - by KCMike - 05-18-2016, 02:12 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 02:13 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 02:23 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 02:30 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 03:16 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 04:30 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 04:42 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 04:44 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 04:48 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 05:35 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 07:29 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 07:40 PM
RE: 37-61 Issues - by Steve Davis - 05-18-2016, 10:58 PM
RE: 37-61 Issues - by Tgace459 - 05-19-2016, 07:22 AM
RE: 37-61 Issues - by Radioroslyn - 05-19-2016, 07:57 AM
RE: 37-61 Issues - by morzh - 05-19-2016, 08:33 AM
RE: 37-61 Issues - by Tgace459 - 05-20-2016, 11:01 AM
Restoring Philco 96
There are currently 7538 online users. [Complete List]
» 2 Member(s) | 7536 Guest(s)
