37-61 Issues
Thanks folks!
I'll try your advice later today when I get home.
I did try some continuity tests on the speaker, but I am still learning so I don't trust my experience to be 100% confident in my results.
I did get continuity on the output transformer, but I couldn't get it on the coil. However my multimeter is a bit finicky with it's continuity test. I can get no continuity at first but then get a positive result when I move/adjust my probes.
On the pin voltage testing. To access the pins on the 6F6G tube it looks like I may have to unbolt that wire wrap resistor from the chassis and pull it out of the way. Is that correct?
37-61 Issues - by Tgace459 - 05-18-2016, 07:53 AM
RE: 37-61 Issues - by KCMike - 05-18-2016, 08:47 AM
RE: 37-61 Issues - by Steve Davis - 05-18-2016, 08:47 AM
RE: 37-61 Issues - by Eliot Ness - 05-18-2016, 08:59 AM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 09:14 AM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 09:18 AM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 10:43 AM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 12:09 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 01:22 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 01:25 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 01:34 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 01:45 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 01:47 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 01:55 PM
RE: 37-61 Issues - by KCMike - 05-18-2016, 02:12 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 02:13 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 02:23 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 02:30 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 03:16 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 04:30 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 04:42 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 04:44 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 04:48 PM
RE: 37-61 Issues - by Radioroslyn - 05-18-2016, 05:35 PM
RE: 37-61 Issues - by Tgace459 - 05-18-2016, 07:29 PM
RE: 37-61 Issues - by morzh - 05-18-2016, 07:40 PM
RE: 37-61 Issues - by Steve Davis - 05-18-2016, 10:58 PM
RE: 37-61 Issues - by Tgace459 - 05-19-2016, 07:22 AM
RE: 37-61 Issues - by Radioroslyn - 05-19-2016, 07:57 AM
RE: 37-61 Issues - by morzh - 05-19-2016, 08:33 AM
RE: 37-61 Issues - by Tgace459 - 05-20-2016, 11:01 AM
Restoring Philco 96
There are currently 6571 online users. [Complete List]
» 5 Member(s) | 6566 Guest(s)
AvatarAvatarAvatarAvatar
