Philco Wirewound Resistor Question
I agree with Terry, that is a really nice one. You should consider leaving it alone if it is good.
Gregb
Philco Wirewound Resistor Question - by Geoff - 05-18-2016, 06:05 PM
RE: Philco Wirewound Resistor Question - by morzh - 05-18-2016, 07:32 PM
RE: Philco Wirewound Resistor Question - by Geoff - 05-18-2016, 08:02 PM
RE: Philco Wirewound Resistor Question - by morzh - 05-18-2016, 10:14 PM
RE: Philco Wirewound Resistor Question - by gregb - 05-18-2016, 09:44 PM
RE: Philco Wirewound Resistor Question - by Geoff - 05-20-2016, 02:42 PM
RE: Philco Wirewound Resistor Question - by gregb - 05-20-2016, 05:19 PM
RE: Philco Wirewound Resistor Question - by Geoff - 05-21-2016, 02:00 AM
Restoring Philco 96
There are currently 7595 online users. [Complete List]
» 3 Member(s) | 7592 Guest(s)
