Bakelite capacitor holders
Yep, that was the bypass in 38-12.
And in 37-116 all blocks (quite a few) had eyelets filled. Wasn't too bad, but this does complicate the process just a little.
Bakelite capacitor holders - by Eric Smith - 05-18-2016, 09:24 PM
RE: Bakelite capacitor holders - by morzh - 05-18-2016, 10:24 PM
RE: Bakelite capacitor holders - by Steve Davis - 05-18-2016, 11:35 PM
RE: Bakelite capacitor holders - by Ron Ramirez - 05-19-2016, 06:09 AM
RE: Bakelite capacitor holders - by klondike98 - 05-19-2016, 08:03 AM
RE: Bakelite capacitor holders - by Eric Smith - 05-19-2016, 04:07 PM
RE: Bakelite capacitor holders - by morzh - 05-19-2016, 08:31 AM
RE: Bakelite capacitor holders - by Ron Ramirez - 05-19-2016, 08:40 AM
RE: Bakelite capacitor holders - by morzh - 05-19-2016, 08:47 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
