Philco 20 and Philco 20 Deluxe
Ron
I know.
I mean, HIS Philco has the rosette knobs. They should be the plain ones like the other one has.
Philco 20 and Philco 20 Deluxe - by Eric Smith - 05-18-2016, 09:14 PM
RE: Philco 20 and Philco 20 Deluxe - by morzh - 05-18-2016, 10:25 PM
RE: Philco 20 and Philco 20 Deluxe - by RadioSvit - 05-19-2016, 02:23 AM
RE: Philco 20 and Philco 20 Deluxe - by morzh - 05-19-2016, 08:45 AM
RE: Philco 20 and Philco 20 Deluxe - by morzh - 05-19-2016, 09:01 AM
RE: Philco 20 and Philco 20 Deluxe - by morzh - 05-19-2016, 05:34 PM
RE: Philco 20 and Philco 20 Deluxe - by SteveG - 05-19-2016, 07:19 PM
RE: Philco 20 and Philco 20 Deluxe - by morzh - 05-19-2016, 08:15 PM
RE: Philco 20 and Philco 20 Deluxe - by morzh - 05-19-2016, 08:56 PM
RE: Philco 20 and Philco 20 Deluxe - by radiorich - 12-09-2020, 12:33 AM
RE: Philco 20 and Philco 20 Deluxe - by GarySP - 12-09-2020, 10:48 AM
RE: Philco 20 and Philco 20 Deluxe - by radiorich - 12-09-2020, 11:52 AM
Philco 91 Tuning Condenser
There are currently 8730 online users. [Complete List]
» 1 Member(s) | 8729 Guest(s)
