philco 60 dial slipping
Morzh  Thank you that is it. Norman
philco 60 dial slipping - by vaguy22 - 05-19-2016, 04:09 PM
RE: philco 60 dial slipping - by morzh - 05-19-2016, 04:22 PM
RE: philco 60 dial slipping - by klondike98 - 05-19-2016, 04:30 PM
RE: philco 60 dial slipping - by Radioroslyn - 05-19-2016, 05:26 PM
RE: philco 60 dial slipping - by klondike98 - 05-19-2016, 08:10 PM
RE: philco 60 dial slipping - by morzh - 05-19-2016, 08:17 PM
RE: philco 60 dial slipping - by vaguy22 - 05-19-2016, 11:00 PM
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:13 PM
