What do I use to clean and polish brown backelite?
I tried today. It is not getting glossy. I get brown on the cloth, meaning it does take off some material, but....no gloss, not even hint.
Well ok, I will settle for matte.
RE: What do I use to clean and polish brown backelite? - by morzh - 05-20-2016, 07:12 PM
There are currently 9768 online users. [Complete List]
» 1 Member(s) | 9767 Guest(s)
