Prepackaged Capacitor Pack for 38-116?
Ed,
I believe that Dave at Justradios will put together a capacitor kit for your radio if you request it:
http://www.justradios.com/
Carl
Northern Panhandle, WV
Prepackaged Capacitor Pack for 38-116? - by Guest - 06-26-2009, 09:33 AM
Re: Prepackaged Capacitor Pack for 38-116? - by Carl Travis - 06-26-2009, 12:51 PM
Re: Prepackaged Capacitor Pack for 38-116? - by Guest - 06-26-2009, 12:55 PM
