Philco 39-6 dial cover and grill cloth.
(05-20-2016, 07:52 PM)morzh Wrote:  1. So what do I glue it with? Sometimes there are staples but I do not want them.
Clear RTV seems to work well. Don't go crazy with it, just a few dots to hold it in place.
RE: Philco 39-6 dial cover - by OldRestorer - 05-15-2016, 07:53 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 08:26 PM
RE: Philco 39-6 dial cover - by KCMike - 05-15-2016, 09:10 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 09:16 PM
RE: Philco 39-6 dial cover - by KCMike - 05-15-2016, 09:27 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 09:37 PM
RE: Philco 39-6 dial cover - by Arran - 05-18-2016, 11:24 PM
RE: Philco 39-6 dial cover - by morzh - 05-19-2016, 08:37 AM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:05 PM
RE: Philco 39-6 dial cover - by KCMike - 05-20-2016, 07:22 PM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:24 PM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:52 PM
RE: Philco 39-6 dial cover and grill cloth. - by Eliot Ness - 05-21-2016, 01:33 AM
There are currently 8733 online users. [Complete List]
» 3 Member(s) | 8730 Guest(s)
