Philco 60 - Problem with Short Wave/Police Band
The 89 coils are well known for moisture absorption so its not a far reach that your 60 coil might have excessive leakage. Check for DC resistance between non-connected terminals and the mounting lug to chassis (if there is one). My 'bad' 89 coil had dc leakage as low as several hundred K-ohms on a DMM.
If you get any resistance at all (save something like 30Megohms) it might pay to bake the moisture out of the coil form and reseal it.
GL,
Bill
91H Code 126 Restore
Philco 70 antenna lead
