16B cathedral side switch
As I am not proficient with woodworking or its terminology, could you explain what "up and over grain" means?
16B cathedral side switch - by morzh - 05-21-2016, 09:42 AM
RE: 16B cathedral side switch - by Steve Davis - 05-21-2016, 11:36 PM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 10:08 AM
RE: 16B cathedral side switch - by Steve Davis - 05-22-2016, 10:12 AM
RE: 16B cathedral side switch - by Ron Ramirez - 05-22-2016, 10:17 AM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 10:29 AM
RE: 16B cathedral side switch - by Eliot Ness - 05-22-2016, 11:54 AM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 01:24 PM
RE: 16B cathedral side switch - by Eliot Ness - 05-22-2016, 01:48 PM
RE: 16B cathedral side switch - by KCMike - 05-22-2016, 02:04 PM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 02:25 PM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 07:46 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6372 online users. [Complete List]
» 1 Member(s) | 6371 Guest(s)
