48-1264 No FM
See the drawing below:
[Image: http://www.philcoradio.com/images/phorum/481264.jpg]
C310 should be connected as shown above in blue.
A jumper wire should be added as shown above in red.
48-1264 No FM - by RWood - 05-22-2016, 02:16 AM
RE: 48-1264 No FM - by klondike98 - 05-22-2016, 09:22 AM
RE: 48-1264 No FM - by Ron Ramirez - 05-22-2016, 10:27 AM
RE: 48-1264 No FM - by Ron Ramirez - 05-22-2016, 10:42 AM
RE: 48-1264 No FM - by RWood - 05-22-2016, 06:52 PM
RE: 48-1264 No FM - by klondike98 - 05-22-2016, 08:43 PM
RE: 48-1264 No FM - by KCMike - 05-22-2016, 08:54 PM
RE: 48-1264 No FM - by RWood - 05-22-2016, 09:03 PM
RE: 48-1264 No FM - by KCMike - 05-22-2016, 10:01 PM
RE: 48-1264 No FM - by klondike98 - 05-22-2016, 11:17 PM
RE: 48-1264 No FM - by RWood - 05-24-2016, 10:17 AM
RE: 48-1264 No FM - by Radioroslyn - 05-24-2016, 12:57 PM
RE: 48-1264 No FM - by RWood - 05-26-2016, 10:38 AM
RE: 48-1264 No FM - by Radioroslyn - 05-26-2016, 03:11 PM
RE: 48-1264 No FM - by RWood - 05-26-2016, 04:06 PM
RE: 48-1264 No FM - by Radioroslyn - 05-26-2016, 05:39 PM
RE: 48-1264 No FM - by RWood - 05-27-2016, 12:07 PM
RE: 48-1264 No FM - by Radioroslyn - 05-27-2016, 01:41 PM
There are currently 3499 online users. [Complete List]
» 2 Member(s) | 3497 Guest(s)
