Philco 39-6 dial cover and grill cloth.
(05-22-2016, 09:56 AM)KCMike Wrote:   + one on making sure your staples are not too long. I did that once to a little table radio I had spent much time restoring. The staples punched through the front in two places. I was able to refill the holes but felt dumb for not checking the length first. Icon_eh
(05-22-2016, 10:19 AM)Ron Ramirez Wrote:  +2. The same thing happened to me on a wood 38-14 I had carefully refinished. Icon_sad Icon_crazy
Yeah, I forgot to mention that I learned the "short staple" rule on a nice little Emerson tombstone many moons ago Icon_redface
RE: Philco 39-6 dial cover - by OldRestorer - 05-15-2016, 07:53 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 08:26 PM
RE: Philco 39-6 dial cover - by KCMike - 05-15-2016, 09:10 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 09:16 PM
RE: Philco 39-6 dial cover - by KCMike - 05-15-2016, 09:27 PM
RE: Philco 39-6 dial cover - by morzh - 05-15-2016, 09:37 PM
RE: Philco 39-6 dial cover - by Arran - 05-18-2016, 11:24 PM
RE: Philco 39-6 dial cover - by morzh - 05-19-2016, 08:37 AM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:05 PM
RE: Philco 39-6 dial cover - by KCMike - 05-20-2016, 07:22 PM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:24 PM
RE: Philco 39-6 dial cover - by morzh - 05-20-2016, 07:52 PM
RE: Philco 39-6 dial cover and grill cloth. - by Eliot Ness - 05-22-2016, 11:28 AM
There are currently 10426 online users. [Complete List]
» 2 Member(s) | 10424 Guest(s)
