16B cathedral side switch
John
If by traces you mean a hole in the frame, which is what I wrote in #1, it is there. On the veneer in fact there are no signs of the hole, so if it was reskinned it was a large piece.
The opposite side of the cabinet had dome damage Kirk repaired but that was not the hole.
16B cathedral side switch - by morzh - 05-21-2016, 09:42 AM
RE: 16B cathedral side switch - by Steve Davis - 05-21-2016, 11:36 PM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 10:08 AM
RE: 16B cathedral side switch - by Steve Davis - 05-22-2016, 10:12 AM
RE: 16B cathedral side switch - by Ron Ramirez - 05-22-2016, 10:17 AM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 10:29 AM
RE: 16B cathedral side switch - by Eliot Ness - 05-22-2016, 11:54 AM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 01:24 PM
RE: 16B cathedral side switch - by Eliot Ness - 05-22-2016, 01:48 PM
RE: 16B cathedral side switch - by KCMike - 05-22-2016, 02:04 PM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 02:25 PM
RE: 16B cathedral side switch - by morzh - 05-22-2016, 07:46 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
