48-1264 No FM
Thanks, that helps. I could, for starters, check each component that is listed on the Possible Cause side.
I frankly did not realize that zooming that part of the service guide would give such sharp detail of the layout. I would have used that during the recap!
Another thought, since this is not being done for alignment purposes, could I use the cheap sine-wave/square wave generator from my old CEI trainer/breadboard? (Anyone remember Cleveland Institute of Electronics?) It looks like I need a 9.1mc modulated output. Could I try this just to see if/where signal is passed?
48-1264 No FM - by RWood - 05-22-2016, 02:16 AM
RE: 48-1264 No FM - by klondike98 - 05-22-2016, 09:22 AM
RE: 48-1264 No FM - by Ron Ramirez - 05-22-2016, 10:27 AM
RE: 48-1264 No FM - by Ron Ramirez - 05-22-2016, 10:42 AM
RE: 48-1264 No FM - by RWood - 05-22-2016, 06:52 PM
RE: 48-1264 No FM - by klondike98 - 05-22-2016, 08:43 PM
RE: 48-1264 No FM - by KCMike - 05-22-2016, 08:54 PM
RE: 48-1264 No FM - by RWood - 05-22-2016, 09:03 PM
RE: 48-1264 No FM - by KCMike - 05-22-2016, 10:01 PM
RE: 48-1264 No FM - by klondike98 - 05-22-2016, 11:17 PM
RE: 48-1264 No FM - by RWood - 05-24-2016, 10:17 AM
RE: 48-1264 No FM - by Radioroslyn - 05-24-2016, 12:57 PM
RE: 48-1264 No FM - by RWood - 05-26-2016, 10:38 AM
RE: 48-1264 No FM - by Radioroslyn - 05-26-2016, 03:11 PM
RE: 48-1264 No FM - by RWood - 05-26-2016, 04:06 PM
RE: 48-1264 No FM - by Radioroslyn - 05-26-2016, 05:39 PM
RE: 48-1264 No FM - by RWood - 05-27-2016, 12:07 PM
RE: 48-1264 No FM - by Radioroslyn - 05-27-2016, 01:41 PM
Restoring Philco 96
There are currently 7594 online users. [Complete List]
» 3 Member(s) | 7591 Guest(s)
