Philco 54
Yep. very clean too!
I have on of those from Kirk. Not sure which 5x it is but very similar. The two big wire resistors are not easy to forget.
I heard they are a b**ch to work on. Too crowded.
Philco 54 - by gregb - 05-21-2016, 10:02 PM
RE: Philco 54 - by morzh - 05-21-2016, 10:34 PM
RE: Philco 54 - by gregb - 05-21-2016, 10:37 PM
RE: Philco 54 - by klondike98 - 05-21-2016, 10:52 PM
RE: Philco 54 - by Nathan Slingerland - 05-22-2016, 12:24 AM
RE: Philco 54 - by gregb - 05-25-2016, 12:24 AM
RE: Philco 54 - by morzh - 05-25-2016, 07:08 AM
RE: Philco 54 - by klondike98 - 05-25-2016, 07:14 AM
RE: Philco 54 - by Nathan Slingerland - 05-25-2016, 08:39 PM
RE: Philco 54 - by Kenneth F. Besso Jr. - 05-25-2016, 08:47 PM
RE: Philco 54 - by klondike98 - 05-25-2016, 09:29 PM
RE: Philco 54 - by gregb - 05-25-2016, 10:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
