Philco95 Condenser Box
I am nearing the end of the under-chassis work on my 95.  The last thing I have to do is to replace the capacitors in the condenser box (item 48 ).   I disconnected all of the wires and removed the box from the chassis.  It isn't clear to me how to open up this box.  Here is a picture:
https://www.flickr.com/photos/104710683@...ed-public/
As you can see, there is a flange that wraps up from the bottom and extends about a half inch or so.  There is one of these on the opposite side as well.  Do I need to bend these away from the side?  Then what?  Give it some heat from the heat gun and pull it apart?
Anything else I need to do?
Thanks in advance.
Philco95 Condenser Box - by PAradiogeek - 05-26-2016, 07:03 PM
RE: Philco95 Condenser Box - by morzh - 05-26-2016, 07:18 PM
RE: Philco95 Condenser Box - by Radioroslyn - 05-26-2016, 07:54 PM
RE: Philco95 Condenser Box - by PAradiogeek - 05-26-2016, 07:57 PM
RE: Philco95 Condenser Box - by morzh - 05-26-2016, 08:12 PM
RE: Philco95 Condenser Box - by PAradiogeek - 05-26-2016, 10:38 PM
RE: Philco95 Condenser Box - by PAradiogeek - 05-30-2016, 10:17 AM
RE: Philco95 Condenser Box - by PAradiogeek - 06-08-2016, 04:10 PM
RE: Philco95 Condenser Box - by Radioroslyn - 06-08-2016, 05:47 PM
RE: Philco95 Condenser Box - by PAradiogeek - 06-08-2016, 06:26 PM
RE: Philco95 Condenser Box - by Radioroslyn - 06-08-2016, 08:31 PM
RE: Philco95 Condenser Box - by PAradiogeek - 06-08-2016, 11:07 PM
There are currently 5764 online users. [Complete List]
» 1 Member(s) | 5763 Guest(s)
