41-290 Help
(05-27-2016, 08:54 AM)morzh Wrote:  Could it be you mixed up the wires while rewiring? 175V at the grids while no plate voltage kinda hints to that.
That's what I'm wondering, but the only thing I rewired was the speaker...I keep checking it, and it looks to be right, at least according to the schematic. Power supply is working great, so I know the field coil is connected correctly. Does it matter which polarity the field coil is in?
41-290 Help - by KC2YSR - 04-01-2016, 08:13 AM
RE: 41-290 Help - by klondike98 - 04-01-2016, 11:28 AM
RE: 41-290 Help - by KC2YSR - 04-01-2016, 11:36 AM
RE: 41-290 Help - by KCMike - 04-01-2016, 11:53 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:36 AM
RE: 41-290 Help - by morzh - 05-27-2016, 08:54 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:57 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 08:57 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:03 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 09:13 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 09:29 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:44 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 10:07 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 10:30 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:08 AM
RE: 41-290 Help - by PAradiogeek - 05-27-2016, 11:22 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:38 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 11:39 AM
There are currently 3859 online users. [Complete List]
» 1 Member(s) | 3858 Guest(s)
