41-290 Help
Hi Michael and welcome!
Measure the resistance from plate to plate across the 41 tubes, methinks your output transformer is open.
Terry N3GTE
41-290 Help - by KC2YSR - 04-01-2016, 08:13 AM
RE: 41-290 Help - by klondike98 - 04-01-2016, 11:28 AM
RE: 41-290 Help - by KC2YSR - 04-01-2016, 11:36 AM
RE: 41-290 Help - by KCMike - 04-01-2016, 11:53 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:36 AM
RE: 41-290 Help - by morzh - 05-27-2016, 08:54 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:57 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 08:57 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:03 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 09:13 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 09:29 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:44 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 10:07 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 10:30 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:08 AM
RE: 41-290 Help - by PAradiogeek - 05-27-2016, 11:22 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:38 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 11:39 AM
