41-290 Help
Plate load for the 41's is 12,000 ohms end to end or 6,000 ohms each side of center tap. This what you need to know to find a proper replacement. Load resistance and dc resistance are two different things. DC resistance is going to be a few hundred ohms.
GLOM
41-290 Help - by KC2YSR - 04-01-2016, 08:13 AM
RE: 41-290 Help - by klondike98 - 04-01-2016, 11:28 AM
RE: 41-290 Help - by KC2YSR - 04-01-2016, 11:36 AM
RE: 41-290 Help - by KCMike - 04-01-2016, 11:53 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:36 AM
RE: 41-290 Help - by morzh - 05-27-2016, 08:54 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:57 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 08:57 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:03 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 09:13 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 09:29 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:44 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 10:07 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 10:30 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:08 AM
RE: 41-290 Help - by PAradiogeek - 05-27-2016, 11:22 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:38 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 11:39 AM
There are currently 5532 online users. [Complete List]
» 2 Member(s) | 5530 Guest(s)
