41-290 Help
Thanks. The 40-180 transformer won't work...It's a single ended output...no center tap. I'll go with the 125B...Seems to be most closely suited to the purpose. I'll report back once I change it out!
Edit: Maybe it will. I was looking at the wrong schematic...It is a dual 41 output. I'll check the part number just to be sure.
41-290 Help - by KC2YSR - 04-01-2016, 08:13 AM
RE: 41-290 Help - by klondike98 - 04-01-2016, 11:28 AM
RE: 41-290 Help - by KC2YSR - 04-01-2016, 11:36 AM
RE: 41-290 Help - by KCMike - 04-01-2016, 11:53 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:36 AM
RE: 41-290 Help - by morzh - 05-27-2016, 08:54 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 08:57 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 08:57 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:03 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 09:13 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 09:29 AM
RE: 41-290 Help - by morzh - 05-27-2016, 09:44 AM
RE: 41-290 Help - by KC2YSR - 05-27-2016, 10:07 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 10:30 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:08 AM
RE: 41-290 Help - by PAradiogeek - 05-27-2016, 11:22 AM
RE: 41-290 Help - by morzh - 05-27-2016, 11:38 AM
RE: 41-290 Help - by Radioroslyn - 05-27-2016, 11:39 AM
