Tube tester covered with Tolex
I would just re-glue for simplicity and for originality.   If when lifting up a section to apply glue it feels like the whole piece will easily peel off you might want to do that.  Then you can glue the whole piece back on.
Tube tester covered with Tolex - by TV MAN - 05-27-2016, 11:24 AM
RE: Tube tester covered with Tolex - by Eliot Ness - 05-27-2016, 11:46 AM
RE: Tube tester covered with Tolex - by Arran - 05-29-2016, 03:03 AM
RE: Tube tester covered with Tolex - by TV MAN - 05-30-2016, 05:24 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-13-2016, 06:24 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-14-2016, 04:25 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-20-2016, 03:10 PM
RE: Tube tester covered with Tolex - by sam - 08-20-2016, 03:23 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-25-2016, 12:15 AM
RE: Tube tester covered with Tolex - by Geoff - 08-27-2016, 02:20 PM
RE: Tube tester covered with Tolex - by TA Forbes - 10-03-2016, 10:26 PM
RE: Tube tester covered with Tolex - by TA Forbes - 10-07-2016, 09:22 PM
Philco 91 Tuning Condenser
There are currently 8979 online users. [Complete List]
» 3 Member(s) | 8976 Guest(s)
