Tube tester covered with Tolex
There is absolutely no reason to re-cover. Spray adhesive on both pieces, wait a few seconds and bond.
I have saved many coverings this way..
The one below was peeled half way off all around...
Me
Tube tester covered with Tolex - by TV MAN - 05-27-2016, 11:24 AM
RE: Tube tester covered with Tolex - by OldRestorer - 05-27-2016, 11:47 AM
RE: Tube tester covered with Tolex - by Arran - 05-29-2016, 03:03 AM
RE: Tube tester covered with Tolex - by TV MAN - 05-30-2016, 05:24 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-13-2016, 06:24 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-14-2016, 04:25 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-20-2016, 03:10 PM
RE: Tube tester covered with Tolex - by sam - 08-20-2016, 03:23 PM
RE: Tube tester covered with Tolex - by TV MAN - 08-25-2016, 12:15 AM
RE: Tube tester covered with Tolex - by Geoff - 08-27-2016, 02:20 PM
RE: Tube tester covered with Tolex - by TA Forbes - 10-03-2016, 10:26 PM
RE: Tube tester covered with Tolex - by TA Forbes - 10-07-2016, 09:22 PM
There are currently 5733 online users. [Complete List]
» 2 Member(s) | 5731 Guest(s)
