Hookup Wire Advice
Pulled the chassis out of my 39-55 I found a couple of months ago and I'm sure you can guess, the rubber wires are completely rotten. I've used salvaged computer power supply cables for years, usually a good color assortment of 18 and 20 awg wire for small jobs. Since the 39-55 has about 2 miles of rubber wires, some quite lengthy,  I need to order some and would like to order an assortment of colors. I know a man can never have too much wire but if I were order some just for radio work, what size, strand count, solid etc. is reccomended  by those who know?
Thanks
Chris
KD7WMZ
Visit Chris' Old Radios and Precision Tube Testers
http://oldradios.50webs.com/index.html
Hookup Wire Advice - by cgholly - 05-27-2016, 09:04 PM
RE: Hookup Wire Advice - by klondike98 - 05-27-2016, 09:07 PM
RE: Hookup Wire Advice - by cgholly - 05-27-2016, 09:21 PM
RE: Hookup Wire Advice - by klondike98 - 05-27-2016, 09:29 PM
There are currently 5512 online users. [Complete List]
» 1 Member(s) | 5511 Guest(s)
