Hookup Wire Advice
Here's some advice from Ron related to the rubber coated wire problem: http://www.philcoradio.com/tech/wiring.htm
Hookup Wire Advice - by cgholly - 05-27-2016, 09:04 PM
RE: Hookup Wire Advice - by klondike98 - 05-27-2016, 09:07 PM
RE: Hookup Wire Advice - by cgholly - 05-27-2016, 09:21 PM
RE: Hookup Wire Advice - by klondike98 - 05-27-2016, 09:29 PM
