  • 1 Vote(s) - 4 Average
Canadian Philco Model 706A (46-1201, 47-1201, 48-1201)
Hello Aaron. Since your turntable motor wont do on 25-30 cycles, anything would be worth a try I suppose? Ive tossed more orig Philco phonos than Id ever like to admit also. If I still had one, I could spare you a good 60 cycle motor indeed!Ive run across several Canadian made Philcos myself, and even the Canadian 25-40 cycle all AC sets transformers ran much "hotter" than usual, after extended time on 60 cycles. Its not supposed to "matter", but I noticed it several times in the past. It took those vintage 25-40 cycle AC trans awhile to heatup, but lordy-mercy,they got there indeed! I swapped em out for 60 cycle trans that I had in backstock from other old sets. Bet you can find a 60 hz motor for it!! I still see lots of Philco consoles in junk-shops these days with orig 60 cycle type turntables still attached.There out there!! Icon_wink
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6239 online users. [Complete List]
» 1 Member(s) | 6238 Guest(s)
