48-1276?
Hi
That is a fine looking console.  I think I have the correct changer for it. It should be a M-4 changer and it should be green, it has a magnetic pickup and it has a very hard to find needle. I am parting out a console that has the M-4 changer and I just put a new needle in it, maybe I have played 5 records with the new needle. let me know if you are interested.
Joe
48-1276? - by sdradioman - 05-26-2016, 10:52 AM
RE: 48-1276? - by Art Hoch - 05-27-2016, 05:58 PM
RE: 48-1276? - by sdradioman - 05-27-2016, 07:16 PM
RE: 48-1276? - by OldRestorer - 05-28-2016, 11:12 AM
RE: 48-1276? - by Ron Ramirez - 05-28-2016, 12:11 PM
RE: 48-1276? - by sdradioman - 05-28-2016, 02:29 PM
RE: 48-1276? - by sdradioman - 05-29-2016, 01:44 PM
RE: 48-1276? - by sdradioman - 05-29-2016, 01:46 PM
RE: 48-1276? - by KCMike - 05-29-2016, 06:13 PM
RE: 48-1276? - by w4rtc - 05-29-2016, 08:20 PM
RE: 48-1276? - by Kenradio - 07-09-2016, 06:39 AM
RE: 48-1276? - by OldRestorer - 07-09-2016, 11:00 AM
RE: 48-1276? - by Joe Rossi - 07-09-2016, 07:16 PM
RE: 48-1276? - by Kenradio - 07-09-2016, 07:33 PM
RE: 48-1276? - by sdradioman - 07-10-2016, 10:50 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
