  • 1 Vote(s) - 1 Average
Rehabing 42-854 AM/SW Portable
#42
(06-02-2016, 09:49 PM)Radioroslyn Wrote:
(06-02-2016, 09:20 PM)morzh Wrote:  Zener is a bad way to do that.
I know but it's simple and doesn't 5 other xsistors.
No it ain't simple and worse than just putting resistors in series.
Zener is justified only where a stable voltage needed with unstable source.
Otherwise you dissipate the same power plus the zener dissipation.
It is the worst way. Like using heavy electric motor as a hammer to drive in nails. Will work but do you think it is a goid use of a motor and is it convenient?
Rehabing 42-854 AM/SW Portable - by Radioroslyn - 05-22-2016, 02:08 PM
RE: Rehabing 42-854 - by morzh - 05-22-2016, 02:29 PM
RE: Rehabing 42-854 AM/SW Portable - by sam - 05-23-2016, 02:33 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-23-2016, 04:40 PM
RE: Rehabing 42-854 AM/SW Portable - by sam - 05-26-2016, 06:55 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-26-2016, 08:06 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-26-2016, 08:45 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-27-2016, 08:06 AM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-27-2016, 11:11 AM
RE: Rehabing 42-854 AM/SW Portable - by sam - 05-27-2016, 11:31 AM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-27-2016, 06:44 PM
RE: Rehabing 42-854 AM/SW Portable - by sam - 05-27-2016, 08:21 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-27-2016, 08:44 PM
RE: Rehabing 42-854 AM/SW Portable - by sam - 05-30-2016, 07:07 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 05-31-2016, 07:22 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-01-2016, 08:04 AM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-02-2016, 01:19 PM
RE: Rehabing 42-854 AM/SW Portable - by sam - 06-02-2016, 12:05 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-02-2016, 07:52 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-02-2016, 09:20 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-02-2016, 09:58 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-04-2016, 02:09 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-04-2016, 04:18 PM
RE: Rehabing 42-854 AM/SW Portable - by sam - 06-16-2016, 10:13 PM
RE: Rehabing 42-854 AM/SW Portable - by morzh - 06-17-2016, 10:32 AM
Restoring Philco 96
There are currently 7857 online users. [Complete List]
» 3 Member(s) | 7854 Guest(s)
