Precise 111m tube tester restoration
I could try that. Is JB weld conductive? I was thinking of some type of epoxy. Still open to ideas.
Tim
Precise 111m tube tester restoration - by TV MAN - 05-27-2016, 11:00 AM
RE: Precise 111m tube tester restoration - by TV MAN - 06-03-2016, 08:08 AM
Eico 232 VTVM Schematic
There are currently 8974 online users. [Complete List]
» 1 Member(s) | 8973 Guest(s)
