Your go to Philco Radio
 41-280 console. Has a nice sound to it with short antenna wire in basement.
Your go to Philco Radio - by PhilcoJohn - 06-03-2016, 07:15 PM
RE: Your go to Philco Radio - by morzh - 06-03-2016, 07:46 PM
RE: Your go to Philco Radio - by titan1a - 06-03-2016, 07:53 PM
RE: Your go to Philco Radio - by Paul Philco322 - 06-03-2016, 07:55 PM
RE: Your go to Philco Radio - by KCMike - 06-03-2016, 08:14 PM
RE: Your go to Philco Radio - by SteveJB - 06-03-2016, 09:00 PM
RE: Your go to Philco Radio - by Squire - 06-04-2016, 01:47 AM
RE: Your go to Philco Radio - by morzh - 06-04-2016, 11:39 AM
RE: Your go to Philco Radio - by 462ron - 06-04-2016, 12:19 PM
RE: Your go to Philco Radio - by kj0002 - 06-05-2016, 06:26 AM
RE: Your go to Philco Radio - by Warren - 06-05-2016, 06:25 PM
RE: Your go to Philco Radio - by shaler78 - 06-06-2016, 09:54 PM
RE: Your go to Philco Radio - by Eric Adams - 06-07-2016, 04:01 PM
RE: Your go to Philco Radio - by Phlogiston - 06-07-2016, 05:37 PM
RE: Your go to Philco Radio - by Groundhog74 - 06-08-2016, 01:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
