subbing eye tubes??
   I have a Rogers console model  9M1091.
  It came with a 6X6 eye tube which is VERY dim. The 6X6 has an octal base.
 Can I sub a Russian octal based   6E5c  tube for the eye tube?
       Thanks   Dan
   Living in Calgary Alberta
subbing eye tubes?? - by Dan Walker - 06-04-2016, 10:01 AM
RE: subbing eye tubes?? - by gregb - 06-04-2016, 10:23 AM
RE: subbing eye tubes?? - by Arran - 06-05-2016, 02:15 AM
RE: subbing eye tubes?? - by Dan Walker - 06-05-2016, 09:43 AM
RE: subbing eye tubes?? - by Arran - 06-05-2016, 11:47 PM
RE: subbing eye tubes?? - by Phlogiston - 06-06-2016, 04:16 PM
RE: subbing eye tubes?? - by Arran - 06-08-2016, 06:24 AM
RE: subbing eye tubes?? - by Dan Walker - 08-22-2016, 08:15 PM
RE: subbing eye tubes?? - by radioswede - 10-25-2016, 01:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
