schematics/parts list philco model 46-1201 code 130
I am restoring a Model 46-1201 code 130 Bing Cosby radio/phono and need a good set of schematics and or parts list? Also, any advice on replacing the R100 and R7 "air" resistors? Thanks.
schematics/parts list philco model 46-1201 code 130 - by Guest - 07-06-2009, 04:58 PM
There are currently 5863 online users. [Complete List]
» 2 Member(s) | 5861 Guest(s)
