Newbie starts big. 41-290X
Welcome!
Even though the wiring according to you looks to be in good shape, these Philcos have rubber insulation that becomes brittle over the years, especially depending on its color.
Even if it does not look crumbled I would check upon it and if it starts cracking upon touching it, you need to replace it, or some of it. My observation, white/yellowish rubber stays pliable, black, green, red crumbles.
Newbie starts big. 41-290X - by AC0GR - 06-10-2016, 12:36 AM
RE: Newbie starts big. 41-290X - by klondike98 - 06-10-2016, 07:55 AM
RE: Newbie starts big. 41-290X - by morzh - 06-10-2016, 08:03 AM
RE: Newbie starts big. 41-290X - by klondike98 - 06-10-2016, 08:06 AM
RE: Newbie starts big. 41-290X - by OldRestorer - 06-10-2016, 08:25 AM
RE: Newbie starts big. 41-290X - by Radioroslyn - 06-17-2016, 08:03 AM
RE: Newbie starts big. 41-290X - by AC0GR - 07-31-2016, 05:17 PM
RE: Newbie starts big. 41-290X - by Radioroslyn - 07-31-2016, 10:52 PM
RE: Newbie starts big. 41-290X - by GarySP - 08-01-2016, 07:38 PM
RE: Newbie starts big. 41-290X - by Arran - 08-04-2016, 01:07 AM
RE: Newbie starts big. 41-290X - by radio dog - 10-13-2016, 06:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
