philco 87 chassis operational????
Even if it is a Y-cap and no electrocutin 's likely, still there could be an unpleasant sensation.
If one is H**l-bent on using it, the value should go down to 2nF and Y-cap has to be used.
RE: philco 87 chassis operational???? - by morzh - 06-08-2016, 08:38 AM
RE: philco 87 chassis operational???? - by Arran - 06-11-2016, 05:04 AM
RE: philco 87 chassis operational???? - by morzh - 06-08-2016, 02:47 PM
RE: philco 87 chassis operational???? - by morzh - 06-11-2016, 12:10 PM
There are currently 5868 online users. [Complete List]
» 1 Member(s) | 5867 Guest(s)
