  • 1 Vote(s) - 2 Average
GE 107 wont start up
(06-11-2016, 02:49 PM)morzh Wrote:
(06-11-2016, 01:51 PM)Tgace459 Wrote:
(06-11-2016, 12:15 PM)morzh Wrote:  The simplest check is, put the ohmmeter across the AC plug, while Off. Turn it on. The resistance should be on the order of a few hundred ohms or less . If very high (Kohms, Mohms), your filaments are open or the tube sockets do not make good contact.
Simplest test first...
I have an "auto range" multimeter that automatically sets the range ( I can also set it to manual range if I wish).
If you mean from spade to spade...when I try this it starts out with a 0 reading and when I turn on the power switch, the display cycle up through a series of Mohm readings 18...19...then returns to 0.
Thing is it doesn't to it every time I turn the switch off then back on again and switching to "manual" and testing various ranges give me 0.
If I test from the + spade to chassis I get 0 when "off" and .474 mohm when "on".
This does not make sense. What you are telling me is you have a short circuit between the plug terminals whether Off or On.
Yeah. im not sure whats going on there. I thought maybe something was "up with" my meter, but it tests resistors very accurately (when I test new ones out of the package).
And to be accurate. The result is not actually zero, as when I touch the the probes together (0.00). It's going back to the "no read" screen (0.L).
I'm using a salvaged cord from an old computer power-supply (two prong).
GE 107 wont start up - by Tgace459 - 06-09-2016, 08:43 PM
RE: GE 107 wont start up - by KCMike - 06-09-2016, 09:00 PM
RE: GE 107 wont start up - by morzh - 06-09-2016, 10:07 PM
RE: GE 107 wont start up - by Tgace459 - 06-10-2016, 12:15 AM
RE: GE 107 wont start up - by Arran - 06-10-2016, 12:22 AM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 02:48 PM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 03:13 PM
RE: GE 107 wont start up - by Tgace459 - 06-10-2016, 01:11 PM
RE: GE 107 wont start up - by leftwing25 - 06-10-2016, 05:28 PM
RE: GE 107 wont start up - by klondike98 - 06-10-2016, 05:40 PM
RE: GE 107 wont start up - by Tgace459 - 06-10-2016, 10:54 PM
RE: GE 107 wont start up - by gregb - 06-10-2016, 11:32 PM
RE: GE 107 wont start up - by Arran - 06-11-2016, 05:28 AM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 11:29 AM
RE: GE 107 wont start up - by klondike98 - 06-11-2016, 11:56 AM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 12:05 PM
RE: GE 107 wont start up - by morzh - 06-11-2016, 12:15 PM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 01:51 PM
RE: GE 107 wont start up - by morzh - 06-11-2016, 02:49 PM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 02:58 PM
RE: GE 107 wont start up - by gregb - 06-11-2016, 12:54 PM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 01:40 PM
RE: GE 107 wont start up - by morzh - 06-11-2016, 01:00 PM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 02:08 PM
RE: GE 107 wont start up - by morzh - 06-11-2016, 03:28 PM
RE: GE 107 wont start up - by Tgace459 - 06-11-2016, 05:03 PM
RE: GE 107 wont start up - by gregb - 06-11-2016, 05:12 PM
RE: GE 107 wont start up - by Tgace459 - 06-13-2016, 12:28 PM
RE: GE 107 wont start up - by Tgace459 - 06-13-2016, 12:51 PM
RE: GE 107 wont start up - by Radioroslyn - 06-13-2016, 01:29 PM
RE: GE 107 wont start up - by Tgace459 - 06-13-2016, 03:15 PM
RE: GE 107 wont start up - by Radioroslyn - 06-13-2016, 04:50 PM
RE: GE 107 wont start up - by Tgace459 - 06-13-2016, 05:07 PM
RE: GE 107 wont start up - by Radioroslyn - 06-13-2016, 05:25 PM
RE: GE 107 wont start up - by Tgace459 - 06-13-2016, 05:31 PM
RE: GE 107 wont start up - by Radioroslyn - 06-13-2016, 05:44 PM
RE: GE 107 wont start up - by Tgace459 - 06-13-2016, 10:19 PM
RE: GE 107 wont start up - by Tgace459 - 06-15-2016, 09:31 AM
RE: GE 107 wont start up - by Radioroslyn - 06-15-2016, 10:04 AM
RE: GE 107 wont start up - by Tgace459 - 06-15-2016, 01:04 PM
RE: GE 107 wont start up - by Radioroslyn - 06-15-2016, 03:14 PM
RE: GE 107 wont start up - by Tgace459 - 06-15-2016, 03:47 PM
RE: GE 107 wont start up - by gregb - 06-15-2016, 07:25 PM
RE: GE 107 wont start up - by Tgace459 - 06-16-2016, 05:33 PM
Philco 89 indicator light.
There are currently 8585 online users. [Complete List]
» 2 Member(s) | 8583 Guest(s)
