Philco 118
I am not sure I understood the part with the socket.
Wish I knew before. I usually heat the body and simply pull a lead, and then pull another, and the guts just follow.
In any case, with cut off ends these caps look normally, same as the other ones without the rolled-up ends when potted with hot glue.
The only thing I should do probably is to buy the colored hot glue, this will look better.
Philco 118 - by morzh - 05-24-2016, 09:07 PM
RE: Philco 118 - by KCMike - 05-24-2016, 09:35 PM
RE: Philco 118 - by morzh - 05-24-2016, 09:44 PM
RE: Philco 118 - by gregb - 05-24-2016, 10:17 PM
RE: Philco 118 - by morzh - 05-25-2016, 07:09 AM
RE: Philco 118 - by Eliot Ness - 05-25-2016, 07:46 AM
RE: Philco 118 - by klondike98 - 05-25-2016, 12:06 PM
RE: Philco 118 - by morzh - 05-25-2016, 02:15 PM
RE: Philco 118 - by morzh - 05-30-2016, 09:04 PM
RE: Philco 118 - by morzh - 06-01-2016, 09:51 PM
RE: Philco 118 - by morzh - 06-01-2016, 09:54 PM
RE: Philco 118 - by morzh - 06-01-2016, 09:57 PM
RE: Philco 118 - by KCMike - 06-01-2016, 10:04 PM
RE: Philco 118 - by morzh - 06-01-2016, 10:26 PM
RE: Philco 118 - by morzh - 06-09-2016, 10:04 PM
RE: Philco 118 - by morzh - 06-12-2016, 11:21 PM
RE: Philco 118 - by Arran - 06-13-2016, 04:23 AM
RE: Philco 118 - by morzh - 06-13-2016, 10:57 AM
RE: Philco 118 - by Arran - 06-15-2016, 04:00 AM
RE: Philco 118 - by morzh - 06-13-2016, 09:21 PM
RE: Philco 118 - by morzh - 06-15-2016, 08:06 AM
RE: Philco 118 - by morzh - 06-27-2016, 12:03 PM
RE: Philco 118 - by morzh - 07-02-2016, 11:51 PM
RE: Philco 118 - by morzh - 07-08-2016, 04:30 PM
RE: Philco 118 - by morzh - 07-10-2016, 07:39 PM
RE: Philco 118 - by morzh - 07-11-2016, 10:36 PM
RE: Philco 118 - by morzh - 07-13-2016, 09:09 PM
Users browsing this thread: 13 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8910 online users. [Complete List]
» 3 Member(s) | 8907 Guest(s)
