Philco 370 Chairside - Veneer Questions
Thanks Terry! I'll definitely avoid a single sheet of veneer. I love this model for how the diamond matched veneer looks on top - really beautiful.
This diamond-matched veneer set from Constantine's would be *perfect* if only it were European Walnut rather than American Walnut:
http://www.constantines.com/walnutdiamon...dface.aspx
I wonder if there's a way to make American Walnut look more like the European variety? :/
RE: Philco 370 Chairside - Veneer Questions - by Nathan Slingerland - 06-13-2016, 09:37 PM
RE: Philco 370 Chairside - by Nathan Slingerland - 08-08-2016, 11:01 PM
