Philco 370 Chairside - Veneer Questions
> European Walnut rather than American Walnut
Pardon my stupidity but what's the difference in appearance??
RE: Philco 370 Chairside - Veneer Questions - by Radioroslyn - 06-14-2016, 01:29 AM
RE: Philco 370 Chairside - by Nathan Slingerland - 08-08-2016, 11:01 PM
Philco 91 Tuning Condenser
