Philco 370 Chairside - Veneer Questions
My understanding is that American walnut tends to be a lot darker than European walnut.
http://www.constantines.com/walnutstripe.aspx
[Image: http://www.constantines.com/ProductImage...nut_qt.jpg]
http://www.constantines.com/walnut-frenchstripe.aspx
[Image: http://www.constantines.com/ProductImage...stripe.jpg]
Obviously there can be quite a bit of variance in color even within a single species of wood, so I think Constantines is just giving the above as 'typical' to demonstrate the average appearance.
I did once mistakenly order some American walnut - and it definitely finishes much darker brown than the wood on our Philcos.
RE: Philco 370 Chairside - Veneer Questions - by Nathan Slingerland - 06-14-2016, 01:45 AM
RE: Philco 370 Chairside - by Nathan Slingerland - 08-08-2016, 11:01 PM
